CentOS - Plex Media Center
Test build of Plex Media Center for CentOS
I'll release my test build into the wild too.
Hardware: Core i5 2390T, Sandy Bridge Asus P8H67I
OS: CentOS 6
Notes: Built using the CentOS guide I added to the github tree README.plex-linux file. So if you need some of the libboost packages I built this on, you can get them here: pmc.markwalker.dk (they are compiled by me on CentOS). The SL6 dir is updated drivers to get it to run on Sandy Bridge hardware with GL acelleration.
The build is from when I was most active on this, but to make it easy to install and remove, I packaged it into an RPM. Hope it installs and runs ok. But please provide feedback if they don't just work.
Get the PMC RPM here: http://pmc.markwalker.dk/plexmediacenter/plexmediacenter-0.1-1.x86_64.rpm
Have fun with it (if it works :) )
/Mark
P.S. I know this is a re-post of my test build. I just think since others are posting arch, deb and so on, I would do an tpm thread.
I try your RPM
after I run the manual install of rpm PMS but ....
[root@ServerLinuxP8 arm]# rpm -ivh plexmediaserver-0.9.6.3.143-1.arm.rpm
errore: Dipendenze fallite:
libdl.so.2(GLIBC_2.4) necessario a plexmediaserver-0.9.6.3.143-1.arm
libgcc_s.so.1 necessario a plexmediaserver-0.9.6.3.143-1.arm
libgcc_s.so.1(GCC_3.5) necessario a plexmediaserver-0.9.6.3.143-1.arm
libgcc_s.so.1(GCC_4.0.0) necessario a plexmediaserver-0.9.6.3.143-1.arm
libpopt.so.0 necessario a plexmediaserver-0.9.6.3.143-1.arm
libpopt.so.0(LIBPOPT_0) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6 necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(CXXABI_1.3) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(CXXABI_1.3.1) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(CXXABI_ARM_1.3.3) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(GLIBCXX_3.4) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(GLIBCXX_3.4.3) necessario a plexmediaserver-0.9.6.3.143-1.arm
libstdc++.so.6(GLIBCXX_3.4.9) necessario a plexmediaserver-0.9.6.3.143-1.arm
libutil.so.1(GLIBC_2.4) necessario a plexmediaserver-0.9.6.3.143-1.arm
but :
Package libgcc-4.4.6-4.el6.x86_64 already installed and latest version
Package libstdc++-4.4.6-4.el6.x86_64 already installed and latest version
for example I've the library :
/usr/lib64/libstdc++.so.6
maybe Is the installation of plex 32bit ?
Colud you help me to solve ?
Thanks a lots.
Best regards.
Its looks like you are trying to install the ARM media server binaries on some arm OS install.
But this thread is for the Plex Media Center rpm.
So if your on arm and your trying to run PMS for arm, I have only had success with it on Fedora Remix 17 for Rasberry Pi.
Could you elaborate on what OS you are installing on?
/Mark
I’m sorry ,
I'm not look that the RPM was for ARM system, I searched RPM for Centos OS . Now I find the repository in official download page :
http://www.plexapp.com/linux/linux-pms-download.php
Great! Few month ago this section was not.
I'm sorry to not help you.
Bye and Thanks a lot for the suggestion.
Your right that it wasn't in the official section until some months ago. There was an unofficial thread since november for it, but now moved into the official section. Hope you enjoy it.
/Mark
