Installing PMS 1.9.1.4272 on CentOS 7
I was prompted to install PMS 1.9.1.4272 on CentOS 7 today, but it failed with Software Center saying that the file was not supported.
I ran a manual install with rpm -ivh command. and this is the last part of the response.
file /usr/lib/plexmediaserver/Plex Media Server Tests from install of plexmediaserver-1.9.1.4272-b207937f1.x86_64 conflicts with file from package plexmediaserver-1.9.0.4252-d07c1f408.x86_64
Here is my uname -a output. Any ideas on how I can resolve this issue?
Linux plex.local 3.10.0-514.26.2.el7.x86_64 #1 SMP Tue Jul 4 15:04:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
When PMS is already installed , you want rpm -Uvh
On Centos, sudo yum install <filename.rpm> also works.
If that fails / issues conflict messages then your rpm db is damaged
As root
rpm --rebuilddb
rpmdb_verify Packages
