Certificate stuck on 429 rate limit - request reset
Same issue here on one of my two servers. I tried shutting it down overnight. Issue persists..
May 20, 2026 09:31:52.847 [128147668089656] DEBUG - [HttpClient/HCl#7ba] HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/a2dfbe64b396ad312bb844a7a7d5369eb6b39608/certificate/csr?reason=missing&invalidIn=0 (reused)
May 20, 2026 09:31:52.847 [128147591150392] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[mod edit: your servers’ certificates are perfectly valid and healthy. Whatever your issue is, it has nothing to do with certificates.]
@robplatt it is done for your #3 server which i could tell had issue
@ttopkcaj @BadFurDay Your’s look fine. Are you getting the CERT error in your server logs like in the post above this one.
Thank you!
Same issue here
May 20, 2026 21:32:34.143 [22607533329208] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
done @thomasdickinson
Hi!
Can you reset mine? Same problem too
‘Error acquiring new certificate: Failed to upload CSR: 429’
done @raphaelgimnecki but it seem to be taking a while to generate a new one so you may have to restart your server.
Can someone at plex please reset mine? Same 429 issue on my windows server. Please and thank you!
[mod edit: please stop and restart your server now.]
Same issue here on my plex server, please help.
Your cert looks fine @hammer94. Do you have the same error ( scroll a few posts up) in your server logs?
@Bigwheel Thank you for checking, my problem has similar symptoms - the Plex player in AppleTV stops from time to time, sometimes not playing at all. It seems to affect 4K HDR10 (HEVC Main 10).
hey @hammer94 the issue folks are having causes them not to be able to connect to their server so they can’t even attempt to start playback. Playback issues would be something else. please make another topic in players category and tag it with Apple tv.
@BigWheel, greetings!
Having the same issue with certs
Found this one in logs today
`May 21, 2026 09:28:18.901 [140601016884024] DEBUG - [HttpClient/HCl#8ca] HTTP/1.1 (0.2s) 429 response from PUT https://plex.tv/api/v2/devices/49536c311dbbf72cce2928f71dac8e74c57cb2f7/certificate/csr?reason=expiring&invalidIn=-396754 (reused)
May 21, 2026 09:28:18.901 [140600946355000] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, `
Good folks from here suggested to write in this forum. Need the same reset on your side
Any info needed from me? Or you can pull this up from my account?
done @doowybbob (might have to restart server)
GOAT!
Everything works now. Have a great day!
I’m not, struggling to see what the error is. Will open a new chat about it though as it isn’t this issue.
Same issue here, certificate expired and since I only allow secure connections, cannot connect to web interface anymore.
Update: Works now, thanks!
My plex.direct certificate expired on 2026‑05‑16 and the server can’t renew. It’s stuck looping on Failed to upload CSR: 429 for several days (PMS 1.43.2, Windows). I’ve stopped the server, removed the cached cert, and let it cool down, but it’s still rate‑limited. Could a moderator please reset my server’s certificate rate‑limit? Thank you in advance!
done @jhubrd You may need to restart your server.
Thanks so much!!
