Certificate stuck on 429 rate limit - request reset
I also have this same cert error / rate limit problem.
Please reset - thank you.
[mod edit: please stop and restart your server now.]
Same issue here, I think.
Thanks!
i’ve reset the ones that have not been done so far.
Me as well please, I see:
DEBUG - [HttpClient/HCl#95c] HTTP/1.1 (0.1s) 429 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx (reused)
In the logs. Thanks!
@man_pl you have two severs on your account. i reset both but looks like only one is current. The certs looked fine and not sure if yours is related to cert as it would be an error like below specific to cert rate limiting
May 17, 2026 14:25:19.440 [140592676825912] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
In any case please try to restart your server.
I don’t see the other server anymore. If you can, would you be able to delete it please.
Spent way too long chasing settings on my end (VM, domains, router, etc.) when checking the logs could have saved me from pulling my hair out… lesson learned I guess.
I need a reset as well, thanks.
@wesley_pipes_igor1 yours is reset
Same here:
May 19, 2026 07:56:08.051 [11944] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
I’m experiencing the same issue and have been stuck for 2 days now. I spent 4+ hours today trying to troubleshoot (firewall rules, NAT/PAT port forwarding, UPnP, DNS, app reinstalls) before finally identifying the root cause in my logs: the CSR upload is being rate limited with a 429 error.
My certificate has been expired for 62+ hours and Plex cannot renew it.
Could a Plex team member please reset the CSR rate limit for my server?
Plex version: 1.43.2.10687-563d026ea
Platform: Windows
Log excerpt:
CERT: Certificate expires soon, fetching a new one.
CERT: Error acquiring new certificate: Failed to upload CSR: 429 - API rate limit exceeded
Thank you.
@OttoKerner
Thank’s guys ! It’s working now!!!
I also need my CSR reset please and thank you
done @jacoballen1002
You rock
Can you check and reset mine?
Been searching for why my aTV’s aren’t working anymore, and I feel this might be the solution.
Thanks!
done @8bt
Hi, same issue here on two servers. Could a moderator please reset the certificate state?
Same 429 CSR issue. LAN access works, remote access broken. Log shows:
Log: CERT: Error acquiring new certificate: Failed to upload CSR: 429, API rate limit exceeded
@BigWheel @OttoKerner — could one of you please reset the rate limit on my account? Thanks.
done @Packarvel77 but one looked fine. it looks like you probably have to restart your servers.
Hi, I seem to be having the same issue, can I get my certificate reset too please?
[mod edit: your server’s certificate is perfectly valid and healthy. Whatever your issue is, it has nothing to do with certificates.]
Same here. Reset would be nice :eye::mouth::eye:
