I want to Change the CEC Mapping in the remote.xml file.
The File is stored in this Folder
./usr/share/xbmc/system/keymaps/remote.xml
But it is read only
I tried this tutorial:
http://openelec.tv/forum/124-raspberry-pi/46793-change-cec-mapping
“cp /usr/share/xbmc/system/keymaps/remote.xml /storage/.xbmc/userdata/keymaps/”
and edited the remote.xml there.
Then i rebooted the pi but the Mapping doesnt changed.
How can i solve my problem ?
You need to adjust the path for PlexHT:
/storage/.plexht/userdata/keymaps/
Thanks works fine now :rolleyes: .
