Change location of data cache
Is there a way to change the path/location the database uses to store metadata and all other required database files? I have the server installed on a fast(yet small) system SSD drive and in order to save space, i’d like to migrate all of actual data to a much larger Media drive. Is this possible?
If it’s a local drive - not networked - easy enough:
Be sure you read ALL the messages in that thread - there are some real gems of knowledge in there you don’t want to miss.
