I would like to change all my movies and tag them as unwatched without having to tag them 1 by 1 and change them.
Is there a way to just select all my movies (several 1000s) and tag them all as unwatched?
I like to clean things up once a year to start fresh.
You should be able to multi-select the items and set them to watched/unwatched. You can e.g. filter the items, select the first one scroll to the end of the list , press Shift and select the last item… then you can mark them as unwatched from the action menu.
IIRC you might need to take care to scroll at a pace that the web app can keep up loading the items in between.
Thanks I finally found how it worked. It does not work intuitively because you first have to tag the first one in the left upper corner and then select the last one while holding shift button, while I would expect some kind of action menu which lets you “select all”.
In the end it worked for me after several tries.
