Just an FYI. We changed the “Solved” button to be “Top Answer” instead. This is because even if there is not a current “solution”, often the current best advice, or feature change, or link to another topic else with a solution, etc may go un-noticed in long threads.
There may be places where you still see “solved” or “mark as solution” i did not catch.
