How about we modify my agent so it does everything and benefits the community with a maintained agent? You know it is maintained yet did not create a bug report…?
What does ‘can’t do the single channel very well.’ even mean ?
Can you attach my scanner logs (if not using my scanner, it’s not goint to support well files)?
I didn’t recognised you were the same guy, apologies.
Update scanner and agent it should be solved now.
Had bugs in both, mostly due to UU playlist format, and wrong variable causing only first 100 eps in playlist to be recognised
@ZeroQI Its all good, do you want to slap in some movie support? no need to make the funhaus one a tv show format since its just a buttload of videos with no direct episodic portion.
@nassenbassen the agent already support movies AND series. If that doesn’t work, please give me the agent logs . If you dump 1000+ movies, it will be messy, better as a series in my opinion
true but it worked, just sorted on air date and it was a-ok. for some odd reason the zeroqi one groups it all in one episode with the letter path name. ill see if i can recreate it later.
