channel plug in only streams to some devices
Hi I have made a plugin that streams fine to the appleTV but dont seem to work in any other client.
its linking to a html5 video stream that is playing an mp4 video
this link has expired but basically I am linking to video feeds like this
https://redirector.googlevideo.com/videoplayback?requiressl=yes&id=cdb7a0783bbaab40&itag=18&source=webdrive&app=texmex&ip=2607:5300:60:400f::1&ipbits=32&expire=1453294810&sparams=requiressl%2Cid%2Citag%2Csource%2Cip%2Cipbits%2Cexpire&signature=2691895132BDC7BF9B4E2B0EAF548D72E7A2DB5B.6E174A1B5E3694E342FF581BE5357BBAAF6BD497&key=ck2&mm=30&mn=sn-p5qlsnzy&ms=nxu&mt=1453280380&mv=m&nh=IgpwcjAzLmlhZDA3Kg0yNjA3OjUzMDA6OmFl&pl=42,43&cpn=&c=WEB&cver=html5
linking to the video this redirects to don’t make any difference
the video is being added with this code
oc.add(CreateVideoClipObject(
url=vidurl,
title=title,
thumb=url
def CreateVideoClipObject(url, title, thumb, container = False):
vco = VideoClipObject(
key = Callback(CreateVideoClipObject, url = url, title = title, thumb = thumb, container = True),
#rating_key = url,
url = url,
title = title,
thumb = GetThumb(thumb),
items = [
MediaObject(
# container = Container.MP4, # MP4, MKV, MOV, AVI
# video_codec = VideoCodec.H264, # H264
# audio_codec = AudioCodec.AAC, # ACC, MP3
# audio_channels = 2, # 2, 6
# parts = [PartObject(key=Callback(PlayVideo, url = url))]
audio_codec = AudioCodec.MP3,
video_resolution = ‘720’,
audio_channels = 2,
container = ‘mp4’,
parts=[
PartObject(
# key = url
key = HTTPLiveStreamURL(url)
optimized_for_streaming = True
if container:
    return ObjectContainer(objects = [vco])
else:
    return vco
return vco
ok I seem to be having a few problems I think are to do with plex,
  1. when looking at the web browser console it shows that some of the video link data is trying to link to 127.0.0.1 when this is not hosted on the computer in question
  2. the transcode url is giving a 404 error from the PMS looking at the log files I see that I am getting transcoder crash reports The crash log dont really seem to show anything useful
    it could be that I am not running it over ssl as get an error saying
    symbol not found: _SSLCreateContext
Ok found the problem and now it streams to all devices before I was using HTTPLiveStreamURL and was under the impression from the documentation that it automatically set the protocol, container, video_codec, audio_codec anyway after setting these values manually it allworked
You probably don’t want to use HTTPLiveStreamURL here, because MP4 and HTTPLiveStreamURL are 2 different types of video.
In the end I got it working by setting all the correct video codec and using a call back function that returned the url after it looked up the correct url feed
return Redirect(url)
