Hi there,
I just tried setting up LiveTV/DVR and during the channel scan at 95% complete there was 44 channels found then at the end it only presented 2 channels. The result is the same if I redo the channel scan. If I use the “HDHomeRun” application on OSX I can find tune all the channels so it’s not a tuner/antenna/signal type problem.
Any ideas what to try next to make that work?
Server Version#: 1.19.1.2621
Player Version#: 4.30.2
Tuner Make/Model: HomerunHD
Guide/Lineup name: TNT Paris IdF OTA Broadcast
Using XMLTV?: No
Channel number/Name: NA
