Channel section...not visible!
Hi everyone... <_<
How could I see the channel Youtube on my ATV 2nd gen ? And in general the channel section ?
I've installed the plugin and I can see it with no trouble on PHT on my iMac, unfortunately on my ATV (2nd gen) I can't see the channels and I'm using PlexConnect 0.4, this is what I can see on my ATV:
I use two Plex accounts to share libraries with my children, so I'm using only the shared library section of the PMS.
Thank you, regards.
Roberto.
Works for me on aTV2 iOS 5.3 untethered:
https://forums.plex.tv/topic/166978-youtubetv-channel-works-in-plexconnect
AFAIK you can't share channels - only library sections. For the channels to work, you got to have direct access to PMS, with the PMS owner's myplex ID. Right?
Thank you Baa, so I'll wait for PlexConnect to support Plex Home and then I'll be ok.
Any ETA for that ?
Regards, Roberto.
Plex Home is supported (we should update the Wiki, though)... but even then you can't share channels with your home members...
Uh, I din't know that, thank you to told me.
I'm looking at Plex Home on Plex web site (documentation) and found this:
Only the admin user of the Home will be able to access Channels.
Does this mean that if I'm connected with that user in my Apple TV 2 with PlexConnect (I mean the trick profile thing!) I can see channels ?
Yes, logged in as the "head of the home" will give you channels - assuming this is the same myplex ID the PMS is published with.
Same without "home" feature: Signing in to myplex with the ID that published your PMS will give you access to channels.
