Where I am located, I have a channel 9 set (e.g. 9.1 9.2 9.3) and a channel 29 set. My issue is if I try to watch live TV or a DVR record a show on 29.1 it changes to channel 9.1, 29.1 is just not able to be viewed or recorded. I am wondering if my tuner card, which is a Hauppauge card has an issue with the speed in which the Plex software issues the commands to change the channel. I am wonder if Plex software may issue the channels like how a user pushes buttons on a remote, the 2 followed by the 9 and maybe, there is too great of a delay between those commands, making my card think that I want to go to channel 2, then 9. If I try to go to channel 29.2 it seems to work as it should. Even the show info is incorrect, it shows the info for the show it is expecting to play/record, but software itself play/records the wrong channel. Trying to watch/record 29.1 is the only one that causes issues…anyone else experience something similar? Even the show info is incorrect, it shows the info for the show it is expecting to play/record, but software itself play/records the wrong channel.
I cannot imagine this being any local config issue, but is most likely a software issue.
