Why do I get this error: “Live TV Playback Failed” “Live TV playback could not be started” only on one or two channels. For instance tonight, I can see 27.1, 27.2, 27.3, and 27.5 but I get this error on 27.4. 27.4 is one of the channels that I often watch. I know the signal is there because I can see it on the split imput to an actual tv. I see the same error on each roku device I’ve got. I thought it might be the channel resolution but I can tune in other standard format channels without this problem. I made sure that there are no other user on at the time. I’m using a HAUPPAUGE WinTV-DualHD in windows 10 for the server. The signal strength for all five channels show all bars in the setup. Any clues?
