Server Version#: 1.41.5.9522-a96edc606
Player Version#: 7.31.7.9854-92c538e56-Plex
Tuner Make/Model: xteve
Guide/Lineup name: Not sure
Using XMLTV?: No
Channel number/Name: USA
You can try turning off “use hardware acceleration when available” on the server.
OR…leave it enabled and adjust the following settings:
In the Plex settings for the client on your Roku, go to video > and set direct play to auto and DISABLE allow direct stream. Then enable allow mpeg 2 and experimental 1080p mpeg2.
See how you get on with that.
Thanks so much for the reply. Unfortunately that did not work.
Any other ideas plexers?
So I believe that the Roku just doesn’t like HE-AAC audio formats. I’ve installed FF-mpeg but I have no idea how to configure Xteve and FF-mpeg to convert HE-AAC to AAC. Can I get some love?
