Hello, I am interested in checking the availability of media (whether or not the media directory is properly mounted). This shows up in the web UI with a warning label that the backing media is not available, however, I haven’t been able to find the same when poking at the REST API.
I plan to tie this together with a script to flag VMware vCenter Application-Level HA to reboot the Plex VM if there are file mount issues.
@dane22 said:
Check the sourcecode for Plex2CSV, since that export it.
Check my signature
/T
I looked through your Plex2CSV this morning and was able to find the checkFiles=1 argument for the metadata query, however, I am not able to see any differences with or without the flag in the resulting XML. I have tried curl’ing the address with and without the flags (with the NFS mounted and unmounted) and diffing the files - they seem to be identical.
Any specific usage help or examples on it?
I tried with and without checkFiles and includeExtras (just in case this triggered something)
http://:32400/library/metadata/3255?checkFiles=1&includeExtras=1
root@plexserver:~# ./vmwareHAWatcher.sh
Wed Apr 27 15:31:01 CDT 2016 Checking Plex status
Wed Apr 27 15:31:02 CDT 2016 Plex status shows UP for movie ID: 4744
Wed Apr 27 15:31:02 CDT 2016 Sending up status
Wed Apr 27 15:31:17 CDT 2016 Checking Plex status
Wed Apr 27 15:31:17 CDT 2016 Plex status shows UP for movie ID: 4744
Wed Apr 27 15:31:17 CDT 2016 Sending up status
Wed Apr 27 15:31:32 CDT 2016 Checking Plex status
Wed Apr 27 15:31:32 CDT 2016 Plex status shows DOWN for movie ID: 4744
Wed Apr 27 15:31:37 CDT 2016 Checking Plex status
Wed Apr 27 15:31:37 CDT 2016 Plex status shows DOWN for movie ID: 4744
Wed Apr 27 15:31:42 CDT 2016 Checking Plex status
Wed Apr 27 15:31:42 CDT 2016 Plex status shows DOWN for movie ID: 4744
Wed Apr 27 15:31:47 CDT 2016 Checking Plex status
Wed Apr 27 15:31:47 CDT 2016 Plex status shows UP for movie ID: 4744
Wed Apr 27 15:31:47 CDT 2016 Sending up status
