Would you mind sharing what agent you’re using and how you’ve organized/named those files?
Also… what exactly do you mean by “Plex says there’s 1 or 2 depending on settings”?
The files are arranged in a Dune Miniseries Directory with each miniseries having it’s own directory. I know that Plex is “picky” about the directory structure thing. I find it very annoying that Plex has NO problem finding Dune and correctly handling it but can’t find and handle Children Of Dune even though these files are part of the same “branch of the tree”. As a software engineer I can say that this is poor design. Plex’s focus is WRONG. It’s job is to play media files. Thus, it’s focus should be file oriented and yet it’s more worried about the directory structure. If the Plex’s focus was where it should be these problems wouldn’t exist to the extent that they do.
GFY… I didn’t give ANYONE and attitude until YOU started with your smart ass comment. You guys just don’t like it when someone who knows what the ■■■■ he’s talking about points out the obvious FLAWS in your piece of ■■■■ server
