Choose a specific poster for all movies in library? (see example)
Hey guys, noob here. I am using "The Movie Database" agent for my movie library and only want the 2nd movie poster available to be used for all movies. Is it possible to tell PMS to choose the 2nd poster for all my movies rather than having to click around a billion times?
There’s no way to do this without editing the agent. Out of curiosity, why the second poster? The posters are ordered by their community ratings on TMDB, so it doesn’t seem like picking the second one would have any kind of consistent effect.
There's no way to do this without editing the agent. Out of curiosity, why the second poster? The posters are ordered by their community ratings on TMDB, so it doesn't seem like picking the second one would have any kind of consistent effect.
Could you point me to any tutorials on editing agents? Sorry I'm really picky, I honestly think the second choice for all movies look cleaner and simpler than the rest. All it has is the pic and movie title, no other tiny wording junk, just the way I like it (Excuse the bad example above. Most movies have complicated posters and the 2nd choice to me is best). I'd be happy to learn how to make this possible, for educational purposes at least..
Interesting. I feel like the first choice from TMDB tends to be the clean one. If you look in your agent settings, you may have another agent ranked higher that’s providing the first poster there (Local Media, e.g.) so you might check that first.
Interesting. I feel like the first choice from TMDB tends to be the clean one. If you look in your agent settings, you may have another agent ranked higher that's providing the first poster there (Local Media, e.g.) so you might check that first.
Actually you're right. I had "Local Media Assets" as first priority which I guess was default. I'd like to refresh all the posters to be straight from TMDB, and the last time I did that nothing happened even after making TMDB first priority. Am I doing something wrong? How can I force PMS to wipe out the current posters and replace them all with the ones from TMDB? Apologies again for the noob questions..
