Choose more than one EPG Provider per Server (Gracenote)
My Problem would be solved, when i could choose more than just one EPG Provider for my Tuners. So please add this ability in an Update. :wink:
Nobody with the same problem and two different tuners?
I have it. +1
I agree. I would like to be able to use a 2nd EPG for a 2nd tuner. I.E. CableCard + Antenna. My antenna picks up some stations that are not provided by my cable company.
Here’s an even simpler method. Allow one EPG, but then be able to manually select a specific channel and match it to a nationwide EPG listing using something like an advanced search wizard. There are maybe 3 or 4 antenna channels that I’d like to manually match up such as Comet TV.
