Is there a way to select a setting specifically for the chromecast? As there are always a lot of issues due to the transcoding bing started it would be great to have some settings in the optimize mune specifically for chromecast.
things that need to be set:
720p or 1090p (4or 8mbps)
MKV/h264 for video
AAC for Audio
AND
webVTT for subtitles
Specifically the audio and subs are important for me, as they require continous transcoding. would be great if we can get those in the selection of optimize.
Have you checked chromecast.xml in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Profiles (on windows)? Not exactly user friendly but ought to give possibilities to adjust multiple parameters. Check the current file and other profiles in the same directory for examples.
Still no Chromecast specific version available? Specifically also the conversion to supported subtitles as that is the main reason my system start to convert…
