Hey there!,
I would like to open this topic because I have problems while casting music from Plexamp and Plex web to my Cambridge Audio CXN100 embedded Chromecast.
When I start the playback, it works fine, it shows direct play in the dashboard but after 10 seconds, it starts to transcode to OPUS and then the audio in the CXN100 is gone, the playing information in the Plexamp app and in the web player continues like everything is good but the audio in the CXN100 is gone, sometimes keeps looping the audio in that last second before the audio is gone.
I tested the music playback using FLAC files with 24bit/96khz, 16bit/44.1khz and MP3 192kbps resolutions, all of them, the same behavior
The curious thing is that I’ve tested the same tracks with my Chromecast Audio, casting from the Plexamp app and Plex web player, everything works perfectly.
I’ve tried to enable and disable full dynamic range from the CXN100 Chromecast options, no change
I attached the logs from the Plex server using a FLAC file 16bit/44.1khz maybe somebody can check what’s wrong, besides the following error:
Aug 18, 2024 19:53:18.464 [784] DEBUG - [Req#682ce/Transcode] MDE: Waiting in Vain: Direct Play is disabled
Aug 18, 2024 19:53:18.464 [784] DEBUG - [Req#682ce/Transcode] MDE: Waiting in Vain: no direct play music profile exists for http/flac/flac
Aug 18, 2024 19:53:18.464 [784] DEBUG - [Req#682ce/Transcode] MDE: Cannot direct stream audio stream due to codec flac when profile only allows opus
Why it only allows opus in the CXN100 and allows direct play in the older Chromecast Audio?
I cannot figure out why transcoding is being enabled in the CXN100 and not in Chromecast Audio device.. but even if transcode is enabled, why the music is gone.
Maybe the Chromecast plugin inside Plex server should be updated to match the newer Chromecast firmware version from the CXN100?
Any hint is appreciated, thank you!
Server Version#: 1.40.5.8854
Player Version#: Chromecast audio firmware 1.56.281627 & Cambridge Audio CX100 Chromecast firmware version: 1.68.cast_20230721_0201_RC09.549871846
ChromecastAudio_WORKS.txt (120.1 KB)
CXN100_NOT_WORKING.txt (412.1 KB)
Plex Transcoder Statistics_CX100.log (87.7 KB)
