Clear Deleted Users from PMS Play History
Server Version#: 1.20.1.3252
I have seen this a few other times but the threads were locked. I have old users (past gf), they are removed from users, but I still get their account name (which they made somewhat inappropriate) in play History. I want to keep most users history data, but there are a few I would like to Purge. Can this option be added or is there a spot in the data folders on the servers where I can remove select Users Play History so they no longer appear anywhere in Plex.
I am somewhat familiar with SQL, but its all working, so I really don’t want to do that nor rebuild the server. I added to Feature Requests section. Just incase I do get bold (I know the Server will need to not be running) but is there just one table I would need to remove them from or are there several?
There is a way to remove the history of a particular user but the effort would be tedious.
  1. All users are maintained by account id
  2. You would need to determine the account id in question
  3. Then remove all references to it. (delete the view history)
It is a very error prone operation.
