Close button and fullscreen button should be switched
Not sure why this was changed in the recent update but why put the close button in the bottom right when most users on a Windows OS are used to having the close button in the top right, currently where the full screen button is. It doesn’t make any sense and makes for a worse user interface.
Please swap them around, thanks.
I agree, this is extremely unconventional! I’ve tried switching the icons with Tampermonkey, but it’s far from perfect yet… I’ll try to share a TamperMonkey script if I’m happy with it, because the people who thought this was a good idea must have been drunk.
I’ve fixed the close button position (and adjusted some other things)
Preview: http://imgur.com/gallery/w2VQS
Changes: Bigger volume bar
Close button to top right
Set playback speed (remembered between videos)
Frame skip with SHIFT-, and SHIFT-. (only assuming 24fps)
Issues: Fullscreen icon now is in the middle top; couldn’t put it to bottom right :frowning:
Tested with Chrome 60
Plex Web version 3.18.2
Plex Server version 1.7.5.4035
TamperMonkey Chrome extension: Tampermonkey - Chrome Web Store
The TamperMonkey script: https://gist.githubusercontent.com/mroosen/8ef2e69c1d753c4d4ed802572f857886/raw/
Have fun :slight_smile:
Preview: Plex.tv UI fixes and features using TamperMonkey - Album on Imgur
TamperMonkey Chrome extension: https://chrome.google.com/webstore/detail/tampermonkey/dhdgffkkebhmkfjojejmpbldmpobfkfo?hl=en
i really like your tampermonkey script i tried making changes to it with zero luck and was wondering if you might be willing to help me make it look more like this as much as the close button bothered me at first i get why they moved it. it’s more that they swapped the buttons so i was wondering if you could help me make one with all the buttons on the bottom.
I’ve spent couple of hours (yes) to get the fullscreen at the bottom too, and failing to do so. The problem is when you append the Fullscreen button to the bottom controls is that it will fail to execute when clicking it. It checks the parent container or something like that and because the parent is not the top controls anymore it fails. I’ve been fumbling around with it for too long and decided that double clicking the video is good enough. The misplacement of the close button was the most annoying thing for me… You can display none it so the top bar is clean, if you manage to find out how to do it, please share though :slight_smile:
Completely agree! I keep clicking the close button when i think I’m clicking full screen!
Not sure how this button switching got past QA (if there is any!) but this is a major issue I wish they’d put right.
Agree on this completely! Please move the close/exit button from the bottom to the top - would make so much more sense. That could also make room for a longer volume bar :smile:
Otherwise, thanks for a great product!
as of today i am no longer able to get the speed control part to work is there anything that can be done to get this working again?
I haven’t experienced any issues with it, which browser have you tested this in?
chrome on 3 different pc’s and on a mac
what browser is it working in?
any ideas how to solve this?
Hi, I’ve made some adjustments for the new Plex version (tested on 1.7.5.4035 server, 3.65.1 client)
Auto update for tampermonkey is not working for me, but you can replace the script with the code below.
I’ve removed some seekbar stuff that broke because of CSS classname changes… I’ve changed the video lookup from a classname lookup to a tag lookup, so it’s a bit more robust for later Plex changes.
your last update worked and seemed to fix the issues but now with the changes to the player again the speed control buttons have disappeared again is there anyway to make the speed controls be added on the new player
really hope this can be added again
