Hi guys, i’m the only one with this problem? Video’s won’t start playing.
Verstuurd vanaf mijn MI NOTE LTE met Tapatalk
Hi guys, i'm the only one with this problem? Video's won't start playing.
Have just tried this, works fine, have you any errors in your log (you need Debug turned on)?
In the log just seeing that it can’t connect to google drive. Are you also using google drive for cloudsync?
Just tried in on the Rpi2 with 0.5.1 also not working. Tried it on the Rpi, same problem. Now using a PHT (openelec) build for my Asrock ion 330, on this device it's working. So is this a Rpi and google drive issue?In the log just seeing that it can't connect to google drive. Are you also using google drive for cloudsync?
I'm using Dropbox, don't have access to Google Drive (I have an aversion to anything Google).
I'm assuming that in Plex you have enabled access to your Google Drive https://plex.tv/cloudsync/providers
Yes, on my phone, tablet, pc and asrock ion with openelec + pht it's working. Just not on the Rpi'sI'm using Dropbox, don't have access to Google Drive (I have an aversion to anything Google).
Have just set up Google Drive and synced a tv show, plays back fine on Rasplex running on RPi2 from CloudSync.
