Codec Install error
Hey,
i install plex on debian and get codec error. My log:
May 11, 2020 09:14:55.724 [0x7f127effd700] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
May 11, 2020 09:14:55.724 [0x7f127effd700] INFO - CodecManager: obtaining decoder 'dca'
May 11, 2020 09:14:55.724 [0x7f127effd700] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/dca_decoder?build=linux-x86_64-standard&deviceId=5011393d-f1c0-4a5a-a8a0-e040497d0e0c&oldestPreviousVersion=1%2E19%2E3%2E2764-ef515a800&version=99c90e0-3095
May 11, 2020 09:15:01.249 [0x7f12bf7fe700] ERROR - Error issuing curl_easy_perform(handle): 28
May 11, 2020 09:15:01.249 [0x7f12bf7fe700] DEBUG - HTTP simulating 408 after curl timeout
May 11, 2020 09:15:01.249 [0x7f12bf7fe700] WARN - MyPlex: failed to update country code, response returned code 408
May 11, 2020 09:15:01.249 [0x7f12bf7fe700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
May 11, 2020 09:15:06.258 [0x7f12a7fff700] ERROR - Error issuing curl_easy_perform(handle): 28
May 11, 2020 09:15:06.258 [0x7f12a7fff700] DEBUG - HTTP simulating 408 after curl timeout
May 11, 2020 09:15:06.258 [0x7f12a7fff700] DEBUG - FeatureManager: Using cached data for features list
May 11, 2020 09:15:06.259 [0x7f123ffff700] DEBUG - DVR: Starting up.
May 11, 2020 09:15:06.259 [0x7f123ffff700] DEBUG - Activity: registered new activity 0dde1470-5210-46bd-8707-50b04015c0f2 - Processing subscriptions
May 11, 2020 09:15:06.259 [0x7f127cff9700] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
May 11, 2020 09:15:10.739 [0x7f127effd700] ERROR - Error issuing curl_easy_perform(handle): 28
May 11, 2020 09:15:10.739 [0x7f127effd700] DEBUG - HTTP simulating 408 after curl timeout
May 11, 2020 09:15:10.739 [0x7f127effd700] ERROR - Codecs: Failed to download XML for codec 'dca_decoder'
May 11, 2020 09:15:10.739 [0x7f127effd700] ERROR - Error configuring transcoder: Decoder install failed: dca
May 11, 2020 09:15:10.739 [0x7f127effd700] DEBUG - Streaming Resource: Terminating session 0x7f128013a610:xnodibqpmesx2nimjgjdb264 which is using transcoder slot.  Used slots is now 0
May 11, 2020 09:15:10.739 [0x7f127effd700] DEBUG - Streaming Resource: Terminated session 0x7f128013a610:xnodibqpmesx2nimjgjdb264 with reason Conversion failed. A required codec could not be found or failed to install.
May 11, 2020 09:15:10.739 [0x7f12fbfff700] DEBUG - Killing job.
May 11, 2020 09:15:10.739 [0x7f12fbfff700] DEBUG - Job was already killed, not killing again.
May 11, 2020 09:15:10.740 [0x7f12fbfff700] DEBUG - Stopping transcode session afafgywq2sckosfwpw3fns5l
Its look like plex.tv cant reach to download codec. I open all ports and reinstall plex. I try to ping plex.tv but it failed … i try to ping plex.tv with extern website found on google and also failed :frowning:
Server Version#: 1.16.5.1488
Player Version#: 3.108.2
please recreate please (DEBUG logging ON, VERBOSE logging OFF)
then download and attach the full logs ZIP file.
same problem
logzip.zip (77.6 KB)
Your system is timing out (network connection) while trying to download the codec
Jul 08, 2020 12:10:20.315 [0x7f86817fa700] ERROR - Error issuing curl_easy_perform(handle): 28
Jul 08, 2020 12:10:25.325 [0x7f86c37fe700] DEBUG - Request: [127.0.0.1:53056 (Loopback)] GET /services/tmdb?uri=%2Fsearch%2Fmovie%3Fquery%3D%26year%3D2007%26language%3Dru%26include_adult%3Dfalse (12 live) GZIP Signed-in Token (andreybrigunetofficial@gmail.com)
Jul 08, 2020 12:10:26.292 [0x7f86b2ffd700] ERROR - Error issuing curl_easy_perform(handle): 28
Jul 08, 2020 12:10:26.292 [0x7f86b2ffd700] DEBUG - HTTP simulating 408 after curl timeout
Jul 08, 2020 12:10:26.292 [0x7f86b2ffd700] ERROR - Codecs: Download failed: Failed to download 'https://downloads.plex.tv/codecs/99c90e0-3095/linux-x86_64-standard/libh264_decoder.so': 408
Jul 08, 2020 12:10:26.292 [0x7f86b2ffd700] ERROR - Error configuring transcoder: Decoder install failed: h264
Jul 08, 2020 12:10:26.292 [0x7f86b2ffd700] DEBUG - Streaming Resource: Terminated session 0x7f86b8104b70:no5d5f6c859d68oflwfxi612 with reason Conversion failed. A required codec could not be found or failed to install.
Jul 08, 2020 12:10:26.292 [0x7f86f2ffd700] DEBUG - Killing job.
Jul 08, 2020 12:10:26.292 [0x7f86f2ffd700] DEBUG - Job was already killed, not killing again.
Jul 08, 2020 12:10:26.292 [0x7f86f2ffd700] DEBUG - Stopping transcode session 107vjs4p4n6d6zfwpxs1fyqn
Jul 08, 2020 12:10:26.293 [0x7f8683fff700] DEBUG - Cleaning directory for session 107vjs4p4n6d6zfwpxs1fyqn (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-107vjs4p4n6d6zfwpxs1fyqn-a1a9c8bf-9f30-4fc2-a4c9-5212130a723c)
