Server Version#: 1.3.8
Player Version#:1.43.1.10611
I’ve been having this issue on some file for a little while.
Last time it happened, it suddenly started working after i spent 5 hours researching to fix it and slowly drifting into madness.
I’ve tried to manually download and put the codec into the right folder.
I’ve tried deleting everything inside the codec folder.
I’ve tried upgrading and downgrading the server.
I’ve switched from the HexOS plex install to a docker container i manually created.
I’ve switched back since and no matter what i do i keep getting screwed by this error coming around and going away without notice.
going to the url from the request manually on my browser i either get a xml that seem to show everything is fine or this :
Can you guys help me fix this.
I dont think its on my side since its a clean install and permission are working since other codec download and work juste fine.
Apr 28, 2026 12:47:54.222 [140405533899576] INFO - [Req#13d8e/Transcode] CodecManager: obtaining EAE
Apr 28, 2026 12:47:54.222 [140405533899576] DEBUG - [Req#13d8e/Transcode/HCl#311] HTTP requesting GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=d3eee51b-dca4-4ba9-a07a-c5a3ee91d463&oldestPreviousVersion=1.43.0.10492-121068a07&version=0dd4de86f2b9bb8b9b397a90
Apr 28, 2026 12:47:54.298 [140405565549368] DEBUG - [HttpClient/HCl#311] HTTP/1.1 (0.1s) 429 response from GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=d3eee51b-dca4-4ba9-a07a-c5a3ee91d463&oldestPreviousVersion=1.43.0.10492-121068a07&version=0dd4de86f2b9bb8b9b397a90 (reused)
Apr 28, 2026 12:47:54.298 [140405552741176] ERROR - [Req#13d8e/Transcode] Codecs: Failed to download XML for codec ‘easyaudioencoder’
Apr 28, 2026 12:47:54.298 [140405533899576] ERROR - [Req#13d8e/Transcode] Error configuring transcoder: Decoder install failed: eac3_eae
