Server Version#: Version 1.15.0.647
After today’s server update it took 2 hours and 6 minutes to remove the commercials from a 30 minute recording. I looked at the comskip included in 1.15.0.647 and it shows as Comskip 0.82.005 public. In 1.14.1.5488 Comskip 0.82.005 donator was included.
I haven’t had any luck with plex commercial skipper.exe (comskip). I always get an error where the video file can’t be processed - one of the other Plex employees mentioned to me that this is as a result of a codec not downloading correctly. Despite reformatting the harddrive, reinstalling windows, and PMS, I still see the same behavior.
You can rename comskip.exe and replace the installed file. Just be sure to include comskip.dictionary and your comskip.ini file in the same directory as well. Good luck.
