No, I only want to know if there is more than one file for any episode at the same time in Plex.
No, there isn’t. Shouldn’t encoding a video remove all metadata anyway?
If you do it with Handbrake, you get a bunch of new, sometimes completely wrong/irrelevant, metadata out of it.
I did it with Handbrake, are there certain settings that I have had to change first before encoding?
No. Unfortunately, Handbrake doesn’t allow you to configure this.
It will always add these meta tags.
Which is why I made it a habit to always either remux the output of Handbrake again or at least use my script to remove the global tags.
So if I understand correctly, we are out of ideas?
Unfortunately yes.
All of the above is working here on my machine (but it’s not a Terramaster NAS).
Ok, @OttoKerner I honsetly appreciate your help. I’m just going to remove the local media assets from the server agent settings.
Thank you so much!
