Is there a way to remove meta info on a movie mp4 file so when i add it to my collection it knows what to name it. i was able to use mp3tag to remove meta info from my tv shows and it found them perfectly
You can use mp3tag to remove tags from mp4 files.
It doesnât matter if theyâre tv shows or movies.
If the âmismatchâ is stuck in Plexâs database, you might have to perform the
Plex Dance
Here is another method to avoid those embedded meta tags from getting too much attention:
Go to
- Settings - Server - Agents - Shows - TheTVDB
In there, grab the line âLocal Media Assetsâ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
- Settings - Server - Agents - Shows - TheMovieDatabase
- Settings - Server - Agents - Movies - Plex Movie
- Settings - Server - Agents - Movies - TheMovieDatabase
i am doing movies to be clear⊠If i put them in to mp3tag they donât show anything but if i put it in to plex it shows the movie name and YTS and plex doesnât know what to name it
Are you judging only by the left area of mp3tag?
If so, take a look into the extended tag dialog:
You can also mark all mp4 files, then right-click on them and click âRemove Tagâ
After you did that, I recommend to perform âOptimize MP4â as well. (can take a long time, since sometimes the whole file will be read and written again.)
This optimizes the file for streaming, by placing all the metadata and header information at the beginning of the file. And Plex is a streaming server after all.
Thatâs because it cannot recognize the movieâs title from the file name.
It doesnât follow the naming rules for movies.
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
This should work better: 12 Strong (2018) - 1080p [YTS.AG].mp4
(the content between angular brackets is supposed to get ignored by Plex. So I recommend you to put anything that doesnât belong to the official title of the movie in there.)
Plex has occasionally trouble recognizing titles beginning with numbers. You can also try one of the alternate spellings of this movie title
i was just about to ask about the file name ok ⊠thank you
You have my curiosity what does optimizing the videos do?
Already mentioned it above.
