Server Version#: 1.21.1.3759
Player Version#: N/A
I deleted and recreated my DVR in order to get switched over to Gracenote. All fine and dandy, but I forgot to recreate the settings to cut out commercials.
So… now I’ve got recordings that missed commercial removal, and are less than pleasant to view.
I tried to run “Plex Commercial Skipper.exe” via command line and ran into codec not supported? What the?
What am I missing here?
Can anyone point me in the right direction?
C:\Program Files (x86)\Plex\Plex Media Server>"Plex Commercial Skipper.exe" "c:\users\myuser\Desktop\Airplane (1980).ts" --ini="c:\users\myuser\Desktop\comskip.ini"
Comskip 0.82.005, made using ffmpeg
Donator build
The commandline used was:
--ini=c:\users\myuser\Desktop\comskip.ini
Setting ini file to c:\users\myuser\Desktop\comskip.ini as per commandline
Using c:\users\myuser\Desktop\comskip.ini for initiation values.
Mpeg: c:\users\myuser\Desktop\Airplane (1980).ts
Exe comskip.exe
Logo: c:\users\myuser\Desktop\Airplane (1980).logo.txt
Ini: c:\users\myuser\Desktop\comskip.ini
Detection Methods to be used:
1) Black Frame
2) Logo - Give up after 2000 seconds
3) Resolution Change
4) Aspect Ratio
ComSkip throttles back from -0001 to -0001.
The time is now 1141 so it's full speed ahead!
Settings
[Main Settings]
;the sum of the values for which kind of frames comskip will consider as possibl
e cutpoints: 1=uniform (black or any other color) frame, 2=logo, 4=scene change,
8=resolution change, 16=closed captions, 32=aspect ration, 64=silence, 255=all.
detect_method=43
;Set to 10 to show a lot of extra info, level 5 is also OK, set to 0 to disable
verbose=10
;Frame not black if any of the pixels of the frame has a brightness greater than
this (scale 0 to 255)
max_brightness=60
maxbright=1
;Frame not pure black if a small number of the pixels of the frame has a brightn
ess greater than this. To decide if the frame is truly black, comskip will also
check average brightness (scale 0 to 255)
test_brightness=40
max_avg_brightness=25
max_commercialbreak=600
min_commercialbreak=25
max_commercial_size=125
min_commercial_size=4
min_show_segment_length=250
max_volume=500
max_silence=100
non_uniformity=500
[Detailed Settings]
min_silence=12
remove_silent_segments=0
noise_level=5
brightness_jump=200
fps=22
validate_silence=1
validate_uniform=1
validate_scenechange=1
global_threshold=1.05
disable_heuristics=4
cut_on_ac_change=1
[CPU Load Reduction]
thread_count=2
hardware_decode=0
play_nice_start=-1
play_nice_end=-1
play_nice_sleep=2
[Input Correction]
max_repair_size=200
ms_audio_delay=5
volume_slip=40
lowres=0
skip_b_frames=0
[Aspect Ratio]
ar_delta=0.08
cut_on_ar_change=2
[Global Removes]
padding=0
remove_before=0
remove_after=0
added_recording=14
delete_show_after_last_commercial=0
delete_show_before_first_commercial=0
delete_show_before_or_after_current=0
delete_block_after_commercial=0
min_commercial_break_at_start_or_end=39
always_keep_first_seconds=0
always_keep_last_seconds=0
[USA Specific]
intelligent_brightness=1
black_percentile=0.0076
uniform_percentile=0.003
score_percentile=0.71
[Main Scoring]
length_strict_modifier=3
length_nonstrict_modifier=1.5
combined_length_strict_modifier=2
combined_length_nonstrict_modifier=1.25
ar_wrong_modifier=2
ac_wrong_modifier=1
excessive_length_modifier=0.01
dark_block_modifier=0.3
min_schange_modifier=0.5
max_schange_modifier=2
logo_present_modifier=0.01
punish_no_logo=1
[Detailed Scoring]
punish=0
reward=0
punish_threshold=1.3
punish_modifier=2
reward_modifier=0.5
[Logo Finding]
border=10
give_up_logo_search=2000
delay_logo_search=0
logo_max_percentage_of_screen=0.12
ticker_tape=0
ticker_tape_percentage=0
ignore_side=0
ignore_left_side=0
ignore_right_side=0
subtitles=0
logo_at_bottom=0
logo_threshold=0.75
logo_percentage_threshold=0.25
logo_filter=0
aggressive_logo_rejection=0
edge_level_threshold=5
edge_radius=2
edge_weight=10
edge_step=1
num_logo_buffers=50
use_existing_logo_file=1
two_pass_logo=1
[Logo Interpretation]
connect_blocks_with_logo=1
logo_percentile=0.92
logo_fraction=0.4
shrink_logo=5
shrink_logo_tail=0
before_logo=0
after_logo=0
where_logo=0
min_black_frames_for_break=1
[Closed Captioning]
ccCheck=0
cc_commercial_type_modifier=4
cc_wrong_type_modifier=2
cc_correct_type_modifier=0.75
[Live TV]
live_tv=0
live_tv_retries=4
require_div5=0
div5_tolerance=-1
incommercial_frames=1000
[Output Control]
output_default=1
output_chapters=0
output_plist_cutlist=0
output_zoomplayer_cutlist=0
output_zoomplayer_chapter=0
output_scf=0
output_vcf=0
output_vdr=0
output_projectx=0
output_avisynth=0
output_videoredo=0
output_videoredo3=0
videoredo_offset=2
output_btv=0
output_edl=1
output_live=0
edl_offset=0
timeline_repair=1
edl_skip_field=0
output_edlp=0
output_bsplayer=0
output_edlx=0
output_cuttermaran=0
output_mpeg2schnitt=0
output_womble=0
output_mls=0
output_mpgtx=0
output_dvrmstb=0
output_dvrcut=0
output_ipodchap=0
output_framearray=0
output_debugwindow=0
output_tuning=0
output_training=0
output_false=0
output_aspect=0
output_demux=0
output_data=0
output_srt=0
output_smi=0
output_timing=0
output_incommercial=0
output_ffmeta=0
output_ffsplit=0
delete_logo_file=0
output_mkvtoolnix=0
cutscene_frame=0
cutscene_threshold=10
windowtitle="Comskip - %s"
cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\""
mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1"
avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n"
dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" "
[Sage Workarounds]
sage_framenumber_bug=0
sage_minute_bug=0
enable_mencoder_pts=0
[NULL @ 03771cc0] ignoring invalid SAR: 40/33
Input #0, mpegts, from 'c:\users\myuser\Desktop\Airplane (1980).ts':
Duration: 01:59:54.76, start: 1.400000, bitrate: 2052 kb/s
Program 1
Metadata:
service_name : Service01
service_provider: FFmpeg
Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), none(top first), 704x480 [SAR 40:33 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn, 90k tbc
Stream #0:1[0x101](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, s16p, 192 kb/s
Unsupported codec!
Could not open video codec
c:\users\myuser\Desktop\Airplane (1980).ts: could not open video codec
