Server Version#: 1.22.0.4163
Tuner Make/Model: Tivo (unsupported DVR)
Plex Pass subscriber: Yes
I record TV with my home Tivo DVR. I have a cron task that will pull download my Tivo recordings, decrypt them and place them in my Plex library.
I was reading through the Plex support articles, and I saw “It’s also possible to enable the commercial detection to run for content in a regular TV library that was not recorded with the Plex DVR”. The catch is that I need to “Have a Plex DVR set up and configured on your Plex Media Server”.
To do this, Plex needs a ‘supported DVR’ configured right? Is there any way to set up the DVR/comskip functionality on (a Linux) PMS without a HDHomerun tuner?
Figured it out. Posting my solution with the hopes that this may help someone else long after this thread dies.
- Cloned tvhProxy from GitHub (GitHub - jkaberg/tvhProxy: An small flask app to help Plex DVR connect with Tvheadend)
- Modified the tvhProxy.py python script to return an arbitrary channel list (in my case just a single channel) instead of actually going out and scanning for channels.
- Run tvhProxy
- Set up Plex DVR and point to tvhProxy with my defined list of channels
- Close/discard tvhProxy
The thought here is that tvhProxy gives Plex DVR just enough info to configure the DVR and enable the comskip functionality. Once the Plex DVR is configured, I close tvhProxy and the Plex DVR just shows that it’s not connected.
The change I made to the tvhProxy was to remove the scan for channels and return just a single channel for Plex:
@app.route('/lineup.json')
def lineup():
lineup = []
# for c in _get_channels():
# if c['enabled']:
# url = '%s/stream/channel/%s?profile=%s&weight=%s' % (config['tvhURL'], c['uuid'], config['streamProfile'],int(config['tvhWeight']))
# lineup.append({'GuideNumber': str(c['number']),
# 'GuideName': c['name'],
# 'URL': url
lineup.append({'GuideNumber': 0,
'GuideName': 'PBS',
'URL': 'http://localhost'
return jsonify(lineup)
