Normally I’m fine with Autoplay having a limit, but I have a special request. My mother who is in home hospice loves watching ‘The Big Bang Theory’. Due to her dementia she doesn’t have a ‘normal schedule’ for sleep. Is there a switch or hack to turn off the timer for Autoplay on the Roku client? I’d get a good night’s sleep and she’d be happy as a clam.
This is no switch to toggle as a default, however there are two options.
- After starting playback, bring up the OSD and press the
repeatbutton, next toshuffle. This will bypass Post Play and play all videos continuously. - You may also create a Playlist. Playlists are exempt from Post Play and will continue to play until the playlist has been completed. (you can also enable repeat here for infinite playback)
