Continuous EPG grabbing
Hello,
I installed PLEX server beta with DVR on a Windows PC and a HDHomeRun tuner.
Initialisation was fine, but now it seems that the EPG grabbing works continuously. I see it working all the time whenever I connect to the server.
I guess this is not normal and uses excessive CPU capacity.
Could someone help ?
Regards,
Arnaud Masson
Me too. It would seem that it takes so long to process that if you sent the update below an hour, it just keeps looping forever.
Thank you ! PRoblem seems solved now…
How did you resolve?
Appears to require:
pms server configed and running
1 client with admin (local browser ok).
I am currnetly trying to import a simple xmltv file to eliminate epg updating.
Hello, now solved…
