Continuous play on home movies
Hi
I have an issue when I play my home movies. Let’s say I have a folder with 15 movie files from our vacation. For me it’s obvious that these clips should run after each other, a continuous play.
For the moment though, you need to step in to one clip, press play, and when that has played go back to all clips again and then press play on the next clip and then do so fifteen times.
Kind of worthless.
Is there no upcoming solution to this?
I have searched but found no solutions on this issue.
/D
Which client are you using? Some clients allow you to play and entire library.
If you are viewing By Folder, this is not a true folder view. It is basically Plex filtering your collection so trying to play a folder is not possible since a list by folder is not a true Plex construct. You can take these videos and add them to a playlist and play the playlist.
I have the same problem. I am using apple TV. Especially home videos - which are of small durations such as 2 to 3 minutes each and there are about 40 of those - it is a big pain having to keep playing them one by one. I wish we have a solution to this problem. creating a playlist with 40 videos would also be a painful experience - as in, not worth the effort.
Im totaly with you on this sunilj10!
No fix for this yet?
BUMP on this! Will continuous play EVER be implemented? Some of us have the PAID Plex account :smiley:
