Control Plex with SNES USB Controller
So, is it possible to control RasPlex with a USB SNES Controller ?
I have this one: http://amzn.to/1zkhU38
That's hard to say for sure without actually testing such a controller with RasPlex.
So if you have both, then just plug it in and try it. Doing so can cause no harm.
But my guess is that it won't work, since it doesn't work with a PS2 gamepad adaptor I tried.
The RPi and RasPlex are designed to work with USB keyboards, and some other USB devices, but gamepads have an entirely different device profile, and I don't think RasPlex has the necessary device drivers to use them.
Best regards: dlanor
I tested it and nothing happens if I press a button on the pad. The controller also doesn't show up in the settings.
Is it possible to use it if I change something in some files?
You'll need to write a new keymaps.xml, search the forums for examples of what to do, or Google, duckduckgo or whatever search engine you use.
Regards
I found the file, but not what I should write in.
You need to search the Internet, there are many ways of achieving this.
Regards
