Server Version#: 1.13.8.5395
Player Version#: web client 3.73.1
plex server log.txt (33.4 KB)
Hello, I get “Conversion failed. The transcoder exited due to an error” Can anyone please help? Thank you.plex server log.txt (393.3 KB)
I also get this error: Jobs: ‘/usr/lib/plexmediaserver/Plex Relay’ exit code for process 11140 is 255 (failure)
May I see the full log please? (recreate if necessary)
I need to see what the MDE decided and what the lead-up is
It turned out to be a connection problem. Thank you for your time in any case.
