Conversion failed. The transcoder exited due to an error
Server Version#: Version 4.30.2
Player Version#: Playing on Laptop
I am getting the following error on screen when trying to play a file in plex.
Playback Error
Conversion failed. The transcoder exited due to an error.
The logs show this.
Jul 11, 2020 19:42:49.386 [0x700004e29000] DEBUG - Job running: EAE_ROOT=‘/var/folders/7y/blplwldd5930tsnxg_vhyyc8zsfftg/T/PlexUpdater-26a819e3-19e2-4c19-b4fd-6b8c89d05ede/pms-7a186221-43f7-4e9d-bece-5c8e8b1687ef/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=‘/Users/xxxxxxxx/Library/Application\ Support/Plex\ Media\ Server/Codecs/99c90e0-3095-darwin-x86_64/’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder’ ‘-codec:0’ ‘eac3_at’ ‘-analyzeduration’ ‘20000000’ ‘-probesize’ ‘20000000’ ‘-i’ ‘/Users/xxxxxx/Movies/TV/xxxx.mkv’ ‘-filter_complex’ ‘[0:0] aresample=async=1:ocl=’'‘stereo’'‘:osr=48000[0]’ ‘-map’ ‘[0]’ ‘-codec:0’ ‘aac_at’ ‘-b:0’ ‘256k’ ‘-f’ ‘dash’ ‘-seg_duration’ ‘4’ ‘-init_seg_name’ ‘init-stream$RepresentationID$.m4s’ ‘-media_seg_name’ ‘chunk-stream$RepresentationID$-$Number%05d$.m4s’ ‘-window_size’ ‘5’ ‘-delete_removed’ ‘false’ ‘-skip_to_segment’ ‘1’ ‘-time_delta’ ‘0.0625’ ‘-manifest_name’ ‘http://127.0.0.1:32400/video/:/transcode/session/ug5qwjimqh71ktaw7540726l/66ecc887-f6a9-48d0-b54a-c5f6549f2548/manifest?X-Plex-Http-Pipeline=infinite’ ‘-avoid_negative_ts’ ‘disabled’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘dash’ ‘-start_at_zero’ ‘-copyts’ ‘-vsync’ ‘cfr’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/ug5qwjimqh71ktaw7540726l/66ecc887-f6a9-48d0-b54a-c5f6549f2548/progress
Jul 11, 2020 19:42:49.552 [0x7000040db000] ERROR - [Transcoder] Invalid decoder type ‘eac3_at’
Jul 11, 2020 19:42:49.554 [0x700004576000] DEBUG - Streaming Resource: Terminated session 0x7fe221b49a98:7bxh7w46ed557khsf9nn3649 with reason Conversion failed. The transcoder exited due to an error.
Jul 11, 2020 19:43:27.228 [0x70000467c000] DEBUG - NotificationStream: Removing because of error
I have attached the file info too.
I have not idea why this file will not play. I have played it fine with VLC.
