Hey there!
I quickly want to present an application I created and used for quite a while now. I thought I might share it, maybe other people can use it as well.
Prepare for:
Coverator!
A simple tool for creating custom covers by combining overlays!
It basically makes your library look more uniform and beautiful:
Features:
- find different covers for a movie
- export the cover you like for easy use in Plex
- you can export different resolutions depending on what you need
- you can overlay version presets (for example: bluray, uhd-bluray,etc.)
- you can overlay edition presets (for example: extended edition, theatrical cut, director’s cut,etc.)
- you can add your own custom overlays!
Tutorial:
ignore the TMDB API Key part, it has been removed!
https://drive.google.com/file/d/1a7RcWhvNlZmHn3QdcYhWBBUQ1NYgk0hN/view?usp=sharing
App:
Version: v0.1
Download:
https://drive.google.com/file/d/1aC3qxv2DOAXjOcjQ2U0AIE3-LxeBpMQd/view?usp=sharing
Additional Notes:
- Since it’s an .exe I created, you antivirus might not like it.
- For now it’s limited to movies only, but maybe I will also add shows or collections at some point in the future.
Best regards!
