Creating library command ends up in empty library
Server Version#:
Hello, looking for help.
Like others on Macbook Pros with an older MacOS (10.13.6) I ran into the “server settings not available” issue. I went back to an older version of PMS (one from April 21), and I can connect to the server again. But now trying to recreate my libraries, I end up with no files in the library. I can scan my music files (folders created by itunes), and I see the scanner going through the files, but eventually the content does not show up in the created library.
Does anybody have an idea what could be the reason for this? Here are my logs.
Thanks for any help
UB
Plex Media Server Logs_2022-11-20_11-20-03.zip (1.8 MB)
You have database issues:
Nov 20, 2022 11:12:32.877 [0x700003c1e000] ERROR - SQLITE3:0x101, 1, no such table: sqlite_schema in "UPDATE sqlite_schema SET sql = replace(sql, 'dt_integer(8)', 'datetime') WHERE name = 'view_settings' AND type = 'table'"
See https://support.plex.tv/articles/repair-a-corrupted-database/
Looks like that was the problem. Thank you so much!
