Libraries just dissappeared
Server Version#: PlexMediaServer-1.27.2.5929-a806c5905-x86
Player Version#: web browser
My libraries are not showing anymore. I see them pinned but nothing is there. When I try to scan the libraries it stops at some point. What can I do?
When i saw the librarie videos aren’t showing up I uninstalled Plex and installed the version listed above.
This is what I see right now but it was showing that yesterday and it never finished scanning or looked like it stopped scanning and the files don’t show up.
A look at your server logs might show what’s wrong with your server (e.g. check Plex Media Server.log for messages with an ERROR - prefix).
Plex Media Server.log (6.5 MB)
What am I looking for?
Did a fresh install and copied over the database file from a restore and it is still hanging up
It seems this might be the errors in your log file indicate some trouble with your database… so you might want to try manually repairing it.
https://support.plex.tv/articles/repair-a-corrupted-database/
Thank you. I ran the sql lite instructions and the index was bad so rebuilt it and it started working immediately. Case closed!
