I'm having a bit of a problem with this Crestron module you've put on Github. Hopefully you can tell me what I'm doing wrong. I've added the module to my user library, it appears in the Symbol Library and I'm able to drag it into my own project. However, when the symbol appears in the Detail View, none of the inputs or outputs have any labels (other than i1, i2, i3, i4). This is weird, since you've clearly labelled them in your Argument Definition in the actual user module. Ah I found a fix - opened the user module in a separate instance of SIMPL Windows, then simply re-saved it as "-mk2.umc" and dragged that resaved module into my project - the I/O names all show up (including the nice grouping you did).
Weird eh? Thought rather than cancel my forum post, I'd post this anyway in case someone else out there ever has the same issue...
I was never able to get it to work, but I was testing with an Android client and think that may have something to do with it. Unfortunately, I haven't had time to WireShark it, and see what's going on...
I’d be interested in this as well. I have a working module for the original Plex desktop that I’ve been using for a couple of years now, but I wouldn’t mind finally making the switch the PHT. Anyone have a module that supplies metadata or album artwork?
Appreciate that you take time from your busy life to do this. As a Crestron programmer this is awesome and just adds to the already existing motivation :)
Hi. I Was wondering if you are still developing/updating your Crestron module for Plex. We are implementing Plex to an all-house AV solution with Crestron being the main controller. Would be great to be able to control Plex via Creston touch panel and/or Crestron iOS App.
Looking forward to hearing back from you.
I don't have plans to create a 2-way module but I do have an update ready which includes numeric input support. The latest version of PlexHT appears to have broken these controls at the Plex/Home user password screen so until this gets resolved I don't plan on releasing the update. The current version does work if you need 1-way PlexHT control.
