Hello
U can find the Pronto File attached to control ur Plex
Im planning to do a module for Crestron and AMX and maybe RTI
Regards
John
Hi did you manage to find a command to start Plex from the Pronto?
i didnt try coz my plex is always running on a mac ;-)
Thanks for the quick reply, it just after a power cut , i need a way to restart it.
its possible with Wake on Lan command
GoPronto for the moment its not my priority but i dont forget it , its in my todo List
if u have more idea … let me know
now in the module we have all information directly in the Pronto
Struggling to get Plex to work with my RTI control system using Harmony IR-codes. Looked on this forum and found your driver for Pronto. Any news on an solution for RTI?
Regards
Tomas
Any updates for AMX module?
Many thanks! )
