Custom Keymaps
I have bought a rii i25 controller and I would like to set up custom keymaps for it.
I have tried the official kodi keymaps from here: https://github.com/xbmc/xbmc/tree/master/system/keymaps
Unfortunatelly it didin’t work for me. Could you please help me how to change keymaps in OpenPHT?
Thank you so much!
I am in the same boat! Did you get any further?
@duckdany and @SteUK
What devices are you running OpenPHT on? And do you have an IR receiver (like LIRC) to capture the IR signals?
The keymaps you listed are not specific to the rii i25 remote. So you can’t just dump them into your keymap directory and expect them to work.
*And I suggest you change the title of this thread to “rii i25 Custom Keymaps” for clarity. Remember, if any solution is found here, it may help someone else. So let’s all try to be clear about our issue titles. Appreciate the tags. :slight_smile:
