Hello all,
In my custom provider I’m currently returning all the metadata in the match response, however I noticed Plex still calls my /metadata endpoint where I also return all the metadata, so my question is what is the minimal amount of metadata do I need to return on the match request?
Also in the documentation they have this:
Image endpoint (Recommended)
The Metadata feature should also provide a /images path for calls to specific items, e.g. /library/metadata/tmdb-movie-123/images. This endpoint should return a MediaContainer object containing and Image Array of all the available image assets for that item.
Example:
"MediaContainer": {
"offset": 0,
"totalSize": 3,
"identifier": "tv.plex.provider.metadata",
"size": 3,
"Image": [
"type": "coverPoster",
"url": "https://image.tmdb.org/t/p/original/qk3eQ8jW4opJ48gFWYUXWaMT4l.jpg",
"type": "background",
"url": "https://image.tmdb.org/t/p/original/3uE9SUywNbj1qSAuYCGgbTTYku5.jpg",
"type": "clearLogo",
"url": "https://image.tmdb.org/t/p/original/rIi0lY2UftYuKDJ4OlIefDdijve.png",
However the MediaContainer object doesn’t have a Image property, at least not in the definition given on the GitHub documentation
MediaContainer
The root object that contains metadata and pagination information.
| Field | Type | Description |
offset |
integer | The starting position in the result set (always 0 for single items) |
totalSize |
integer | Total number of items in the response (always 1 for single items) |
identifier |
string | The provider identifier (e.g., “tv.plex.provider.metadata”) |
size |
integer | Number of items in the current response (always 1 for single items) |
Metadata |
array | Array containing a single movie metadata object |
Will Plex accept a MediaContainer with an Image property or should it be a MediaObject with a Metadata object that only has an Image array, and I assume all the other required properties of a Metadata object?
Allen
