My Plex Server runs on a Win10 Machine by the way. So I entered the local path of my PKCS12 file (tried both extions .p12 and .pfx). The PKCS12 file itself is stored in the local userprofile. So access rights shouldn’t be an issue either.
Then I entered my private key (It doesn’t really say if you need to enter the path to the .key file or the private key itself, but I tried both) Right now I’ve configured the plain text private key again, as I assume this is the expected value for this field.
And of course the DNS name which I used for my CSR:
Now when I connect to my Plex Media Server I get a weird *plex.diret certificate, which of course causes a COMMON_NAME mismatch:
Why don’t I see the certificate I installed? Did I miss something?
Also tried various browsers and Chrome Private mode to make sure it is not a cache issue.
Also whats weird is that when I save the settings I don’t get any kind of feedback like “Success” or “Fail”.
hey guys, any news on that topic? don’t wanna be nagging, but I don’t know another way to get support for plex than this forum. and as I am a plex pass user I guess I’d be egliable to get support right?
if I am mistaken here pls tell me. I know this is not a high priority issue, but any kind of response from a plex official would be highly appreciated, even if it is just “we are busy with other topics” or “shut up already”)
then I’d at least know that someone registered this topic.
@flow said:
Nope. You are not. You should have read what you bought. lol
interesting. I actually didn’t know that o_O
thx for that info. thats an answer I can live with
in that case I’ll keep trying to solve it on my own and post the solution here if I stumble upon it.
FYI, the log posted shows that Plex can read the cert (since it knows expiration date).
With certificates the name has to match or it will fail. Technically speaking you can continue past the error, but I don’t know as much about Plex’s rules surrounding certs.
Does that cert show let’s encrypt as the organization that validates the cert? If not Plex isn’t honoring the cert and is replacing it with it’s own. Like I said, I don’t know Plex’s certs, I just see that I am using https and the channel is encrypted…
Yes it shows LE as certification organization. Not sure, but I guess LE certificates would be accepted by plex.
Anyway I will post this topic on reddit and as soon as I find a solution I will post it here. (Link to the reddit post will follow)
I guess it’s working only when you have a public domain for your plex server. Install SSL cert in your public domain, Plex will take care the rest. I haven’t use this feature yet. But if you use https://app.plex.tv/desktop url its already has SSL cert installed. If you are accessing plex server locally, then you don’t need SSL at all.
This is my own idea.
