I’ve been trying to get this going and no luck, every time I change the template to plex tit stops connecting give unavailable message I have to delete settings from atvsettings.cfg to regain access, seems just setting the template freezes it.
Any suggestions???
Sent from my iPhone using Tapatalk
Install teamviewer and we can temporarily control your computer together. I just need the random temporary user id and password teamviewer generates to assist you. Click my name to send me a message with the info if you want to give it a try,
No gui really just ubuntu server running the daemon for this and transmission only 2 tasks this computer should have, I have uninstalled and reinstalled pillow, with sudo apt-get install python-pil and still nothing I can grab some logs if ud like but it doesn’t show much just gets stuck…
Pip install pillow exits in error when I try it
Ok think I got it noticed on ATVSetting.cfg when I selected plex the setting saved is
template = Plex
Notice cap P, seems a simple change it should be plex not Plex, idk but does it matter that I have a case sensitive file system??? Asking cause I did not have this issue on my imac
Xwk88
