Server Version#: 1.43.3.10828
Player Version#: 127.0.0.1
Interesting Y Axis!
I also noticed that when Remote exceeded 1TB (first time ever for me) that the figure above the bar stayed at 1TB until it hit 2TB. So from 1.0TB to 2.0TB I had no visibility on exact usage at the GB level, the way you get from 0GB-999GB.
It is merely a rounding error of the scale. Just read the higher 1TB as 1.5 TB and you’ll get an accurate-enough estimate.
This will most likely not get fixed, as the web app will eventually be replaced.
Sorry to hijack this bit but can you point me to more info about this? I seem to have missed that the Plex webapp is being replaced. I thought I was keeping up on most Plex development but this is catching me off guard.
@mi5ha - the dashboard has always been kinda vague-ish and if you want more insight I think folks tend to use WebtoolsNG or Tautali for more complete monitoring. Either of those might help you out.
I don’t think there has been any particular announcement since it will be a while. The web app is likely to be the last updated due to all the management stuff in it.
