Dashboard Customization
How about the ability to Enable/Disable each entry on the Dashboard. If I don’t want to see “Recently Added TV Shows” in the dashboard, I go to a setup page and select disable that entry.
Customizing the Dashboard is not currently possible.
Will this be possible again in the next update / soon?
This was a feature that I loved on the previous version.
I hope you took some pictures and videos of those bygone days. You’ll be able to remember them with fondness as you live in these new days.
Plex don’t do ‘options’.
