Is it possible to remove certain TV shows from the Dashboard? I dont care for those TV shows I just keep them cause other users watch them.
Which part of the dashboard are you referring to? The Up Next? or the recently added? etc
“Include in dashboard” is a per library function so you can do what you want to do only if you place the unwanted shows in a separate library and set the “Include in dashboard” flag to off for that library.
