Hi!
I recently transitioned over to a WD MYCLOUD Pro; from a Windows PC. However, my dashboard now appears incomplete. I’m logged into my admin account; however, my dashboard now only shows recently added movies and TV. There is no section for recently aired or recently released. THe issue exists on the web and IOS.
Any ideas?
I believe that’s Plex’ standard behavior when showing the start page.
You can select the “Discover” view for an individual library and it’ll show all sorts of dashboards.
No- it’s showing all the libraries- but it used to break it out and show recently released movies or recently aired shows. Now it’s just showing recently added TV and movies.
here you go…
default view “All Libraries”
changed to my library “Filme” (lit. Movies)
behavior in iOS is similar… 1st you select the library, then you switch between discover and browse mode.
Thx. I had really thought that all that info was on the discover tab. Guess not.
Thanks again
